- Aug 10, 2019
- 2,556
- 5
- 0
oteloj said:They cost so much. But does it really worth it? How to choose it? Thanks.
acalex said:I am very intrigued to try the Clearaudio Magix which is supposed to completely decouple the turntable from the platform...will get 3 of them next time to try and report back
basshound said:acalex said:I am very intrigued to try the Clearaudio Magix which is supposed to completely decouple the turntable from the platform...will get 3 of them next time to try and report back
Am I looking at the right things £235 each ? Seems a bit overpriced.
drummerman said:basshound said:acalex said:I am very intrigued to try the Clearaudio Magix which is supposed to completely decouple the turntable from the platform...will get 3 of them next time to try and report back
Relative.
Worth it if the TT is reasonably expensive and it makes a difference. - Expensive otherwise.
regards
RobinKidderminster said:I tried sqash balls. The shop refused a refund. But for a few quid I didn't regret trying. Good luck. Wanna buy 8 rubber hemispheres?
drummerman said:RobinKidderminster said:I tried sqash balls. The shop refused a refund. But for a few quid I didn't regret trying. Good luck. Wanna buy 8 rubber hemispheres?
Are you saying they refused to take back the halfed squash balls ... ?
Outrageous
regards
Outrageous
regards
