does sky output an S-Video signal?
tommyb
87
I have regular sky and I am going to connect to my Onkyo 875 - should I just use a regular composite video lead to the amp, or could I use a Scart - S-Video + 2 audio (phono) and connect that to the amp instead? which would give the better upscaled pic?
I seem to remember reading that sky doesn't output an s-vid signal.
Will be connecting to a Panasonic 42PZ85
Sky+ definitely has S-Video out but I can't remember if the standard Sky box does. Have you checked the back? S-video is definitely preferable to going the composite route if you have the choice. Otherwise it's definitely worth upgrading to Sky+ if you're not considering going HD for a while.
FuzzyinLondon:Sky+ definitely has S-Video out but I can't remember if the standard Sky box does. Have you checked the back? S-video is definitely preferable to going the composite route if you have the choice. Otherwise it's definitely worth upgrading to Sky+ if you're not considering going HD for a while.Hi, yes some standard sky boxes have an s video output i for one have got one on my Grundig sky box, im not certain but i believe it was only grundig that did the s video out although panasonic may have?
