Do hifi cables benefit from burn in (or running in)?
  • Yes
    Votes: 2 9.1%
  • No
    Votes: 18 81.8%
  • Not sure
    Votes: 2 9.1%
  • Total voters
    22
Deleted member 188516
i have not noted burn in / a difference with the cables i have used...but i have not tried all designs hence i'm in the "not sure" option which is not a poll choice !
(i have noted no differences with the 8 or so loudspeakers i have tested burning in either i may add...)
I've added a 'not sure' option - too late for you so my apologies!
thanks - i've clicked the not sure option !
edit :- my "not sure" vote has not been added (?)
Deleted member 108165
A certain nameless party seems to be absent from this thread but his most ardent admirer has commented.
gfong
13
I think over time a cable will settle in and give a more relaxed sound. If doing this for 40 hours before you hook them to your speakers gets them burned in or if you just plug them in to your speakers and listen for 40 hours to burn them in, I think the end result is the same. The sound does change in my opinion.
