Interesting video, and a nice dig at Danny from GR Research 😀
Being afraid of the truth is common. You can learn to break free from that. Believe in yourself.I see his face, I'm out.
Do you mean you hate it when people provide verifiable evidence that does not support your opinion.I see his face, I'm out.
😂To me Op amp swapping seems very similar to tube rolling with a valve amp.
You either hear the benefits or you don't.
However you'll never know until you try.
Apologies but I haven't actually watched the video.😂
I think you're missing the point. People thought they heard differences in the GR Research test but someone noticed that the volumes were slightly different - the discrete one was slightly louder.
Tubes are not the same as their distortions are in the audible range - that can be shown with measurements.
It's a proven fact. That's why volume matching is so important.Apologies but I haven't actually watched the video.
So you're saying volume differences will make them sound different?
Yes, it is the same with tube rolling.To me Op amp swapping seems very similar to tube rolling with a valve amp.
Look up Fletcher Munsen curves to see how the response of the ear varies with volume.Apologies but I haven't actually watched the video.
To me if a B Flat doesn't sound like a B Flat then it has nothing to the volume it is played at......Look up Fletcher Munsen curves to see how the response of the ear varies with volume.
Bill
As I said in my reply it's only superficially similar, since the distortion levels are so different.Yes, it is the same with tube rolling.
I think I got lucky, it doesn't always translate to better sound, it may present the music in a different way or give a better balance or make it worse. I like the sound of my replacement tubes better than (but not substantially) the generic ones.
For sure. I have an very extreme example from personal experience: I attended a concert where the volume was actually too high. Some parts, guitar or keyboard solos sounded out of tune to my ears. When I heard the recordings (made on my phone) of the same concert at home at a much lower volume, everything sounded OK. And I know, this is a very extreme example, but you can imagine if you compare equipment with 1 or 2dB difference in volume the sound will be different. And don't forget that some speakers need a bit more power before the start singing and dancing. It can be just that small difference (when I was studying I worked part-time in the local hifistore and sometimes we used this trick to sell speakers which had a better margin).Apologies but I haven't actually watched the video.
You're making assumptions there.Being afraid of the truth is common. You can learn to break free from that. Believe in yourself.
I don't mind verifiable evidence if the results have been arrived at with 100% accuracy, which isn't always the case. Hearing him say things like, "I don't know why the company is doing this", (followed by some negative talk) and then not doing the research to find out and understand why doesn't really inspire confidence in his conclusions.Do you mean you hate it when people provide verifiable evidence that does not support your opinion.
Bill
If you look at many of his videos, they confirm just how good a lot of the recommended items recommended by users and subjective reviews are, (In other words he provides verifiable evidence of those reviews) however if verifiable evidence proves that the subjective reviews are wrong (Or misheard) he points that out with the evidence.You're making assumptions there.
This man runs a forum that isn't too dissimilar to far right groups - outsiders and any who dare question their beliefs are set upon by his many minions. It's extremely fanatical. He may not do it, but he allows it to happen, which is just as bad. You have to ask yourself which side has a more negative effect on those just getting into the hobby.
To me, he just sounds like someone who has a beef with the industry and is trying to undermine it. Like a few people round here...
Content deleted by moderation.You're making assumptions there.
That some of the verifiable evidence he provides doesn't match with your opinion is by the way, on the other hand, if you can provide verifiable evidence that he is wrong, then do so, that way the user can make their own decision.
Bill
I'm not disputing what he measures, and I'm not disputing what he thinks of those measurements - but he doesn't always measure correctly, and he doesn't always investigate further when he gets a "bad" measurement to find out if it's something he did wrong, or for the reason behind it - it's either good or bad. There may have been an intentional design decision for that measurement. There's no communication with the manufacturer or designer, it's just automatically a 'bad product', which is then ridiculed and badmouthed by the natives, most of whom will never hear that product during their lifetime. He measured some satellite speakers once, and made numerous comments about their lack of bass - duh, a satellite speaker is a an intentionally bass limited speaker designed to be used with subwoofers - not taking into account its intended use is just completely fail in my opinion.If you look at many of his videos, they confirm just how good a lot of the recommended items recommended by users and subjective reviews are, (In other words he provides verifiable evidence of those reviews) however if verifiable evidence proves that the subjective reviews are wrong (Or misheard) he points that out with the evidence.
Bill
Just the sort of tactic that gives dealers a bad reputation.....we used this trick to sell speakers which had a better margin).
Absolutely!Every one has a right to express an opinion and we should have the grace to listen with common courtesy. 👍
