DJ Krime can you please help?
Hi DJ Samsung PS5096FD arrived yesterday in a huge box! Certainly looks fantastic with HD feed from ps3 and your recommendation was much appreciated!
At the moment I watch freeview through a media centre xp laptop but are struggling a little getting this set up properly. The desktop display does not fill all the screen and is shifted to the left hand side, I currently have the output set at max resolution 1920x1080. I have found the option to move adjust the position of the input left right up down etc however this does not seem to work or move the computers output. There is also a green/blue/red section at the bottom of the tv screen about an inch below the bottom of the windows taskbar.
Sorry to post this here but I couldnt find a pm option. But I guess if anyone else has this plasma and can help that would be great.
I look forward to hearing from you
Carl
Glad to hear it has arrived and You are happy with it, and Yes the box is a Big ******!
How Is your PC conected? In the Manual under the section about connecting your PC to the TV there is a list of PC resolutions that the screen will accept. Check that the settings on your PC are the same as those in the Manual as I had to adjust the settings on My pc to get a crrect image at 1080. Have you tried the PC on a lower resolution? If so what happens then? Do you stil have a Non-full screen image?
