Directional speaker cables
grdunn123
293
6
18,895
Just a quickie.......have some speaker cable with arrows pointing one way on the sleeving, should the arrows point to the speaker or the amp???
professorhat
992
22
18,895
Really? I've always assumed the arrows point the way the signal should be travelling, in which case arrows should be pointing to the speakers...
professorhat
992
22
18,895
Good stuff - you had me questioning my entire belief system for a moment there, John!
John Duncan
2,034
30
19,720
fatboyslimfast:It's Friday JD - you are excused
And frankly, my head is full of numbers like this:
Dw Prob Sta Val Diff Dw Prob Sta Val Diff Abs Dw Prob Sta Val Max
-260,018,740 260,018,740 1,124,331,617
-235,461,504 235,461,504 487,890,660
-142,487,460 142,487,460 1,193,118,442
-74,840,841 74,840,841 606,811,958
-74,610,548 74,610,548 241,186,778
-39,641,404 39,641,404 68,543,557
-36,083,991 36,083,991 317,018,576
-27,867,484 27,867,484 75,555,935
-16,502,216 16,502,216 2,130,727,112
-12,766,725 12,766,725 414,929,054
-10,272,045 10,272,045 181,874,668
-7,215,533 7,215,533 618,757,227
-1,335,492 1,335,492 8,873,820
7,040,368 7,040,368 34,017,882
18,481,806 18,481,806 85,746,569
27,082,362 27,082,362 202,787,888
47,247,006 47,247,006 252,422,959
81,415,106 81,415,106 1,028,154,463
86,014,667 86,014,667 653,577,833
128,112,001 128,112,001 1,193,566,646
clearer_audio
Hello grdunn123,
Yes as John said the arrows should be pointing towards the speakers (i.e., in the direction of the signal). Most manufacturers indicate directionality with speaker cables simply due to the way in which the conductor material has been processed. With interconnects directionality can also be due to shielding configuration. However you may also want to try the speaker cable the other way as may find that you prefer the cable connected in this way.
Hope this helps.
Kind regards,
Darren
