poriya said:
			Hello everyone..
I have question about blurays or cd players devices wich responsible for just having audio digital output  (Not analoge)...The question is in term of digital signal are there any differences between devices where they just make digital audio  out (and price tag shows yes there is)..because digital signals are unique (0 or 1) and all of them should do it flawless....
Thank you in advance
If your DAC / Processor is sensitive to clock jitter, then it is possible that the quality of the transport may matter. Jitter is a real effect, and the commonly used S/PDIF connection can make matters worse.
On the other hand, if your DAC / Processor has jitter mitigation circuitry (as many do these days), or uses an asynchronous interface like async USB then there should be no audible difference between a £20 drive and a £1000 shiny transport with a fancy name.
There have been many studies on the level at which jitter becomes audible.  To complicate matters, jitter is a random process and not all jitter is created equal. The most easily detectable jitter is correlated in some way to the programme material.  Unfortunately 'code correlated jitter' is just the type that the S/PDIF connection introduces.  If you have the patience, then there are studies on the net that suggest that jitter is inaudible below 200nS rms, and others that suggest the jitter in the 10s of pS can be heard.  I think a lot depends on the type of jitter being used for the study.
In an ideal world, the clock used to drive the D2A chip should be very stable, and stuck right next to the D2A chip on the circuit board.  Anything else that relies on a transport in a different box, a 'sidecar' or whatever for a clock is always going to be a compromise.
