Designing a cinema room
grahamboyd
40
Having hassle with this post.
It should have also said:
Floor: 5mm thick fibreboard underlay and on top acoustic carpet underlay.
Is this enough. no one above so can leave ceiling. What about behind skirting boards?
Graham
chrisup
49
Hello Graham
I used to work for a leading Carpet Manufucturer on large contracts eg BBC, HTV, BSBSky Central TV Barbican etc. I would recommend you either use a 40 ounce underfelt or Tredair and install a carpet with as many tufts per inch eg wilton or axminster. Your biggest problem will be bass as the higher frequencies will be absorbed if you dont crank up the volume. I used speaker stands in my flat and as the higher off the floor the better. I spoke to my neighbours and kept the volume down at night but in the daytime I turned up the volume. We once carpeted a wall because the studio was having an ingress of noise but the carpet met the highest fire ratings as I used it on Cruise liners and cross channel ferries.
I hope this helps
Best wishes
Chris
