Denon DM 37 connection to PC
Hi there,
Just wondering if anyone knows if it's possible to connect my Denon DM37 to a PC or laptop?
Amanda
When you say connect it to the PC I am assuming you want to run the PC sound through the Denon. If so, it depends upon the outputs on the PC. You could use RCA to RCA or 3.5mm Jack to RCA.
If you do literally mean connect the Denon to the PC then it does have RCA outputs.
Thanks Messiah. I'll give it a try and let you know how it goes.
