Denon AVR1910
Please help to advise on this matter, just bought a Denon AVR1910 for my room (4900 by 3700sq ft).
Should I go for B&W CM5 & CM centre 2 or Bose Acoustimass16 speaker system or MT30 B&W
Mano
I would go 4 d B&W's, The Bose are small but will lack much weight, and clarity at high levels, and the sub is too small in my opinion to cover such a frequency range. i Paired my 1910 with a Pair of Wharfedale 9.5, CS centre and the 9.1's for rear and it really goes great even with music, I.ve heard Bose with Music amd they are really weak on that side, so if you are using the system with music to consider that.
manogaran09:
Mano
Thamby, this is a repeat of your previous post.
