- Aug 10, 2019
- 2,556
- 5
- 0
Hi all,
I decided to bite the bullet and audition the above home cinema combination with a view to buying. I decided to change the 686 rears for a pair of M1's due to room size (4.5 x 3.5m) and also decided to upgrade the sub to the ASW610.
The setup was fantastic with movies, really immersing you in the sound. However, when it came to music, I thought it was a little laid back. Would this combination be expected to sound laid back with CD's or is this more likely to be down to:
a) a lower end panasonic blu-ray player being used as the source
b) the 685's being a long way from any walls
c) the layout of the demo room (it was a loft conversion so had a low sloping roof)
Any opinions would be great.
