- Aug 10, 2019
- 2,556
- 5
- 0
I am looking to build a home cinema system that will also double up for HiFi duties. I'm no expert but I know the conventional wisdom amongst reviewers goes along the lines of "Multichannel amplifiers can sound ok, but a dedicated 2 channel amp will always give better sound quality". However, let's suppose I go out and spend £2,000 on a reasonably high end multichannel amp. Can anyone give an approximate idea of the price-comparable stereo performance I could expect to get from this system? In other words, approximately how much could I typically expect to spend on a stereo amplifier if I wanted to get the same 2 channel performance? Or put another way, what would be a sensible amount to spend on a partnering CD player?
I realise that this will vary enormously between different products, but can does anyone know if there is an approximate rule of thumb, e.g. that on average a multichannel amp will produce a stereo performance of a 2 channel amp costing, say, half, or a third (or whatever amount) of the price?
Reviewers never seem to make this very clear. I subscribe to WHF and every issue seems to contain comments like "this is one of the most musical multichannel receivers at this price point", but it leaves me with no real idea of the level of performance.
Just one final question: suppose I were to take the opposite route and buy a seperate CD player and 2-channel amp. Would it then be possible to wire these up to the front speakers of the multichannel setup? (Obviously not to receive a signal from both amps at the same time, but just connected so that I could listen to either music or movies through the same speakers.)
Thanks in advance for any tips.
