Dedicated CD Or Losless digital + Squeezebox
legoyoda
7
HI all,
Does anyone have any first hand experiance on the benifits of dedicated CD over a Media server running Apple losless and a Squeesebox. Both would be running to the same AMP (Thinking NAD C326BEE as everyone raves about it). andthe CD player would be a NAD C545Bee if I whent that route.
Auditioning is tricky as the only local Hi-Fi shop closed a year ago so just wondering if the CD player would be worth the outlay over the media streaming option in terms of audio performance.
Gerrardasnails
295
legoyoda:
HI all,
If you went lossless to squeezebox and then to a DAC (Beresford or DacMagic), I would bet that it would sound better than the Nad cd player.
matthewpiano
Buy a decent entry level CD player (CA 340C or NAD C515BEE) to use as a transport and an off-board DAC like the Beresford, V-DAC or DacMagic. The DAC can then serve your CD player AND your laptop/computer and you'll get the best of both worlds. No need for the Squeezebox either.
I recently bought a Dacmagic and Squeezebox. I'll answer your question in 2 stages.
1) I use FLAC files not Apple Lossless but theory is they are the same.
When playing tracks from my laptop (my equivalent of a media server), connected to DAC with a USB cable I cannot detect any difference in sound quality compared with playing the same track on my CD player.
2) When streaming the same track through the Squeezebox there is a very slight drop in the overall sound quality. But it is very small difference and not enough for me to worry about.
The computer / Squeezebox setup is much more flexible than a standalone CD player - and I would definitely recomend it.
Gerrardasnails
295
heystak:I recently bought a Dacmagic and Squeezebox. I'll answer your question in 2 stages.
Just to add to Heystak's post, his cd player's rrp a couple of years ago was £900.
legoyoda
7
Wow, some seriously fast replies there. Thanks people!
OK well it looks like the Squeezebox with a DAC is a good option especially as the slight drop in quality was to a 900GBP player! I'll start loking at DAC's
Gerrardasnails
295
legoyoda:
And here is the 5 star review it received......
http://whathifi.com/Review/Arcam-DiVA-CD192/
