I have PMC OB1 speakers, both of which have indent damage to the lower dome. I cannot notice audibly significant change as I would have expected. I cannot seem to find repairer for it so wonder if I need to change/upgrade
No you (obviously) don't...... wonder if I need to change/upgrade
I agree. You will always hear when a speaker is blown or damaged. A long story, but I managed to blow my OB1s twice.No you (obviously) don't.
If they're just dented (not torn cones) could you not carefully pull out the dents?
Thanks. The indents are quite deep and have tried heating them up and then using vacuum cleaner but no luck. Noticed some special tiny Allen key for removal so will try and source these to push out properly, to continue enjoyingNo you (obviously) don't.
