Dali Zensor 7 or Ikon 6 Setup for 5.1 Home Theater
chirag_bhalla
Hello,
I am setting up a dedicated home theater system and the size of the room is 18x14 feet. I am really confused between Dali Ikon6 and Zensor 7. For me it will be 70% movies and 30% music. I am planning to use a Denon AVR-2100. Is it worthed to spend extra for Ikon's?
I would really appriciate you kind reply for the same.
Chirag
nugget2014
215
you need to hear both before making a decision but I have demoed both the zensor 5 and ikon 6 and the ikons blown away the zensor 5s by miles. The only difference between the 5 and 7s is driver size and bass I guess. The ikon 6s sounded more lively, vibrant. And I thought the subwoofer was on when it infact wasn't! Biggest bass from floorstanders I have also heard. Definitely get the ikons. I've had lots of demos of floorstanders even a few over £1000 and they all sound meh compared to the ikons. If I had the money I'd buy them also.
