Schubertplant5 said:My dad ....
MakkaPakka said:Schubertplant5 said:My dad ....
Have you tried comparing the Epicons to your Ikon in the same setup?
I've heard the Epicon 2 but way out of my price range, not sure how Dali's other models compare.
Garett said:The wharfedale 121 were also good but couldn't keep up with the pace and agility of the Dalis when it came to fast paced rhythms.
matthewpiano said:paddyb, I don't think there is a definitive answer to your question. The Dalis will give you a bigger sense of scale and even more detail than the Wharfedales, but perhaps not quite the same sense of cohesiveness which has long been a strength of the Diamond range. I'd suggest an audition!
paddyb said:matthewpiano said:paddyb, I don't think there is a definitive answer to your question. The Dalis will give you a bigger sense of scale and even more detail than the Wharfedales, but perhaps not quite the same sense of cohesiveness which has long been a strength of the Diamond range. I'd suggest an audition!
Thanks Matthew. I've already gone one step further than that actually, I've reserved a pair at Richer Sounds as I have a "£50 off any speaker package" VIP Club voucher that expires next week, couldn't resist! Will pick them up midweek and try then at home and they'll give me a refund if i'm not happy.
More detail and scale sounds like what I'm looking for, but I have trouble with all the jargon connected with Hi Fi, especially speakers. I'm not quite sure what you mean by "cohesiveness" and in the WHF review, the only negative they had was that they lacked a little "refinement", I don't know how this would be different from "detail", nor exactly what the difference is between "authority" and "scale", I think this means a more expensive, "bigger" (no not necessarily louder) sound but might be completely wrong!
paddyb said:Garett said:The wharfedale 121 were also good but couldn't keep up with the pace and agility of the Dalis when it came to fast paced rhythms.
I made pretty much the same decision as you, home auditioned the Zensor 1's, really liked them, but not quite enough bass for my liking, so ended up exchanging them for the Wharfdale 121's. But now seriously thinking of getting some Zensor 3's, if these had been available earlier in the year I'm sure I would have gone for them straight away. So, do you think it's worth the upgrade from the 121's?
