Dali ikon MK2 or Dali E12F sub ?
JamesMellor
40
Hi guys ,
Is the IKON worth the extra 80 quid over the E12F , I will be running all Dali LFR speakers and have my real hi-fi running Dali's and may at some future point upgrade to make two systems one ( big costs there that I don't want to think about yet ) , I dont want to go cheap now to go more in 6 months , my budget is 500 notes give or take , room is 5 x 6m but half open plan
themovierooms
70
The short answer is yes it is a much better sounding subwoofer. The only drawback is the obvious one, the Ikon is a big beast so you will need to have the space to fit it in.
JamesMellor
40
Are you a dealer ? I could really use some informed help the only locals i have left are richer sounds and music matters , the MM guy is good but he dosnt stock DALI
