- Aug 10, 2019
- 2,556
- 5
- 0
Hi guys
Following your advice, research and listening to lots and lots of speakers, I am a very proud owner of DALI Ikon 6 floorstanders. I am building my first hi-fi system from scratch and decided to start with the speakers.
I tried out MA RX6 (too compressed/not enough separation), MA GS20 (too small soundstage), Spendor A5 (too dark - too much in the low mids), Epos M22i (too bright), Quads (just... average), B&W CM7 (loose bass), B&W 683 (even looser bass) and the Dali's were by far and away the best sounding-speaker. I just couldn't get enough of the huge, raw, clear and wide sound of the DALI's. That comes with the proviso that seem highly tempramental, so I have to choose the amplifier & CD player very carefully.
The main issue with the DALI's seems to be that they need an amplifier that is very articulate and clean, but that has a warm and musical bass. The only complaint against the Ikon 6's is that the frequency range where the fundamental notes of the bass instruments are seems a bit muted... you can feel but not hear the actual notes. Hence I really need an amplifier (/cd player combo) that will add a bit more OOMPH to the bass, to really bring the bass NOTES forward.
I tried the DALI's with Primaire i30, which had lovely detail and separation, but did not push the bass enough. Musical Fidelity M6 (wildly outside of my budget!) gave the DALI's an excellent bass response - exactly what I was looking for, but did not have enough clarity and separation across the rest of the range.
My only other experiences with amps were with Roksan Kandy K2, which seemed a little too forward in its approach, and with Creek Destiny (again slightly outside my price range) - but it was an excellent piece of gear...
So, what amp would you recommend to pair with the Ikon 6's, specifically bearing in mind that I want the amp to dial in some more musical/warm bass, but still have a lot of articulation & separation of instruments and musical clarity?
(I listen to progressive rock/metal/classical/jazz/fusion)
Budget: £800 MAX (for integrated amp alone) or £1400 MAX (for CD & amp) - happy to consider ex-demo / used gear...
Once I find the right amp, I will look for CD player & turntable to pair with it - however if you know a combo that would work well, please suggest!
Many thanks guys
Roman
Many thanks guys
Roman
