DAC upgrade, £800 budget
Genny
hello, i'm running a matrix quattro & genelec 8030A setup and i feel like its the time to upgrade.
£800 budget, and i'd definitely prefer if it was black.
I think at that price point, the most highly regarded DAC is probably the Audiolab MDAC. But you might want to try a few out and listen to some before you buy.
I was going to say the Benchmark, but it is above your budget, especially if you go high enough up the range to use it as a remote controlled preamp. In the UK I'd have to agree that the M-DAC would be the prime candidate.
Personally I use an Pioneer U-05, but I'm not in the UK and the pricing differences would probably make the M-DAC the better proposition for you.
I have to say i prefer the look of the Pioneer U-05, really classy looking bit of kit, also gets great reviews, so worth auditioning - especially if you use headphones! Seen it in UK shops for £650 now so pretty close to the M-DAC in terms of price.
If you can demo a hegel h25.
Having recently upgraded my amp to hegel i cant say enough good things about them. Its all about sound quality. Id also look at chord dacs as Dave at frank harvey mentioned
