DAC to headphones without amp.
Blackdawn
88
Is it possible to hook up headphones to the analogue output (L and R phono) of a DAC such as the rDAC or Dacmagic? Maybe there is a connector you can get to do this? Also would it work? i.e. is the ouput power too low to run headphones? This would save having to get an amp as well.
Cheers :)
idc
1,142
117
19,370
There are a few vintage headphones, such as the AKG K1000 that can run off the phonos out of an amp. Otherwise modern headphones are way too sensitive and you should look for an amp with a jack socket.
