cyrus help
ivang666
9
hi,some help if possible,currently using kef r300, cdi with psx-r, 6a amp,wanting to know can i bi amp to my 6a,if so is this difficult,do you split the speaker cable over both amps as the diagrams suggest?what should i buy cyrus x power?,this bi amping has me flustered,can somebody put me on the right road
Gazzip
88
Not sure it's worth it mate. R300's are, from personal experience, easy to drive so I'm not sure what you would gain much improvement from doing this. If you have a few £100 to spend on an upgrade then either upgrade the whole amp or move on to the R500's, also from personal experience.
