Cyrus 8 DAC review, few questions
Zubkabera
131
I have few quesions regarding new Cyrus 8 DAC review, your review doesn't mention how does it perform compared to earlier 8xpd, is it worth the upgrade?.
On the upgrade is it only power supply which has been upgraded and rest of the components are same as old xpd, also review doesn't say much about upgrade path does PSX-R worth an upgrade if the power supply has already been upgraded ? how about dac is the upgrade is same to QX version or there is new DAC available as well?
Secondly I was surprised to read that it "Can be fussy with partnering kit" to me rack would have been a least concern on fussyness in SQ as long as it is staying on solid rack. I was expecting some guide on speakers, speaker cables & interconnects.
Based on the amplifier you have, your next worthwhile step is pre/power combinations. Or at least adding a power amplifier to get more from your Dynaudios.
I reccomend adding the 8/ X power to your setup, makes a big difference. Then 2 PSX-R a few years down the line or all at once if you can. Huge improvement on great recordings, but makes you realise most cds/ recordings are not great at all
