CXN DSD64
Hi Andrew, I can't say definitively what's wrong but hopefully can help you work it out.
1. are all of the firmware updates installed as DSD support only came as part of a firmware update?
2. how are you getting the files to the CXN - DSD is only supported over upnp (network cable or wifi) or UBS hard drive?
3. If you're using a NAS, what make and model?
4. why have you connected the CXN and CXA with an optical cable? The DAC setup in the CXN is slightly more sophisticated than the CXA so I would connect the two together using analogue RCA cables to take advantage of the CXN DAC rather than rely on the CXA DAC.
