Cutting a rejoining a sub woofer cable?
roger06
374
I've buried the sub woofer cable under the carpet and, like a total fool, didn't leave enough length on the hi fi side of the room to move my system where I want it (on the side of the room where the sub is there's about 3 m spare - doh!)
It seems like my options are:
1. to clear the room, pull up the carpet, pull thru more cable and pay the fitters to return and re lay the carpet
or
2. Can I cut the cable and re join it to give me the length I need ?
The cable has plugs on each end and I don't know whether it's single strand or a coax.
What do you think ? I appreciate doing this may compromise quality a little but it's not exactly an expensive sub!
roger06:
or
You can buy an adaptor like this - I had to.
http://www.audiovisualonline.co.uk/dynamic/eshop_products.set/ref/48/single-phono-adaptor/display.html
Gerrardasnails:roger06:
or
Thanks - and then just buy a short length SW cable presumably ...
Even though the subs a cheapie, your talking about signals that are quite difficult for cables to fully allow through. Cutting the cable into 2 is just going to make it worse. So personally id do a full job with one length of cable ~ unless your REALLY not bothered (shrugs).
Believe me I'm bothered!! We went on holiday while the carpet was being fitted and I'm REALLY angry at myself for not pulling enough cable through !
I've ordered a connector and another shorter length of cable which I reckon is a good compromise between cutting the existing cable and the hassle of taking up the floor...
I just wish I could rid my AV system of this loud buzzing - but that's aother story !
roger06:Gerrardasnails:roger06:
or
Exactly.
