CROSS OVER SETTINGS FOR SPEAKERS
steakers
102
What are the typical speaker cross over settings when speakers areset to smalli am using a sub and bould like some help in setting my system up right .
Frank Harvey
567
It depends what the auto setup of the receiver has chosen as the crossover point/points. Generally, 80Hz is a good place to start, and you can experiment upping or dropping it by 10Hz, if your receiver allows.
Andrew Everard
1,878
Indeed: the Missions you have claim to go down to 75Hz, so I reckon a setting of around 80Hz or 90Hz, set in the receiver's manual crossover settings menu, should be about right.
The default 'small' setting rolls off the speakers at 120Hz, if I recall correctly, which I'd suggest is a bit on the high side.
steakers
102
thanks guys do you recommend i set all the speakers to 80 then which the amp does go down to , or just the fronts and centre .
thankyou
