Critical VTA . . . !!!
CJSF
251
A subject visited on more than one occasion . . . it generally ended up as a bland option. Personally one has always been in the 'important adjustment' camp.
Having made an upgrade on my P5 TT with the use of an acrylic platter mat, presenting a thickness issue? Standard felt mat is nominally 2mm thick, the acrylic mat is 3mm. You will have read how pleased I am with the improvements; 'old cynic that I am'.
The extra 1mm thickness bugged me . . . as such things do? . . . So I decided to try raising the arm by 0.5mm. Replacing the 1mm shim with one of 1.5mm.
. . . what a disappointment, the sound became boxy, lifeless and generally ordinary . . .
As the title of the thread suggests . . . VTA is critical, the difference is like night and day!
CJSF
Lost Angeles
130
CJSF said:
A subject visited on more than one occasion . . . it generally ended up as a bland option. Personally one has always been in the 'important adjustment' camp. Having made an upgrade on my P5 TT with the use of an acrylic platter mat, presenting a thickness issue? Standard felt mat is nominally 2mm thick, the acrylic mat is 3mm. You will have read how pleased I am with the improvements; 'old cynic that I am'. The extra 1mm thickness bugged me . . . as such things do? . . . So I decided to try raising the arm by 0.5mm. Replacing the 1mm shim with one of 1.5mm. . . . what a disappointment, the sound became boxy, lifeless and generally ordinary . . . As the title of the thread suggests . . . VTA is critical, the difference is like night and day! CJSF
So you have vinyl records that are 3 different thicknesses and are you going to make an adjustment every time you play something. 8)
chebby
1,251
24
19,195
I sense an impending missive on the subject of laziness and 'fit and forget mentality' :)
CJSF
251
No way Chebby, I know what I hear and how to deal with it . . . from now on, thats as far as I go!
CJSF
CJSF
251
? . . . nope, seem to have hit the sweet spot, if this evenings 3 hour Horlicks session is anything to go by . . . 8)
CJSF
chebby
1,251
24
19,195
I think you neef an arm (or arm mount) that will enable VTA to be 'dialled in'.
As ' Lost' correctly implies, LP thickness can differ by at least 0.5mm (especially those audiophile jobs) so that 'sweet spot' will be all over the place.
Either that or have a couple of mats (thin for thick LPs and vice versa).
Sospri
28
Do you not think that it could be your reinstallation that could be at fault maybe......
CJSF
251
Tried various thickness, there is a minor change in sound on the thickest , but the general presentation is maintained, so as I say, the 'sweet spot' has a small latitude. As most of the records I listened to yesterday, over two 3 hour sessions were OK and I consider them to be a fair representation of my collection, I'm happy. Record thickness/VTA is an on-going problem whatever the vinyl setup might be . . . ?
CJSF
CJSF
251
No chance, my dog could do it with one paw tied behind his back and blindfold . . . :? A figure of speech before someone twists what I say, accuses me of animal cruelty and reports me to the RSPCA:bounce:
Woof! . . . woof! . . .CJSF
stevieg330
I find CJSF's comments really interesting. I often read articles saying that there is a sweet spot where everything comes into focus.
On my deck I use the Michell VTA adjuster and a while back I decided to see if I could find this 'sweet spot' I put three dots on the adjuster using a felt tip pen and went through the complete range of adjustment in 3rd of a turn increments from low to high.
I have to say I never heard a difference at any point! To me it sounded exactly the same regardless of the arm height. I tried different records of varying thickness, still nothing. Now it may be that this is unique to my deck but after spending some hours on it getting nowhere, I decided that Roy Gandy was right and set the arm more or less horizontal and have left it like that ever since.
That's my experience anyway.
Steve
CnoEvil
556
11
Sospri said:
I dunno about that coat he's wearing !!!!
Does his street cred no good at all
It's technically known as a Grill...ie. Covers the Woofer. :shifty:
CJSF
251
stevieg330 said:
Steve
:? . . . There are a few factors at play, one is using a low slung counter weight, this moves the centre of gravity closer in line with the stylus, better controlling the arm movement in relation to the stylus in the grove. Now you can reduce the down force on the stylus, tiny, tiny amounts, its done by ear, then the VTA changes will (might) be audible? Its a round and round process, takes time patience and practice. This is my method that suits my system.
CJSF
