Connecting Toshiba laptop to Sony KDl 40z4500 LCD Tv
anderc02
71
Hello, What is the best way to connect my Toshiba A200 laptop(3yrs old) to my Sony TV .The laptop has a 15 pin pc port and usb. Could I use the LAN port on the TV without going via a broadband router ?
Look on the back of the tv for a 'D' shaped connector with 15 pins marked 'PC IN'. This will allow you to view the laptop on the big screen. You will also need to run an audio cable between them if you want to hear sound.
The LAN ports are generally used to connect both items to a network or router, not to connect them together although it may be possible to use a crossover cable to do this if your laptop gets internet from a usb mobile internet device and you want to share it with the tv.
