Connect iPad to KEF LS50 Wireless II
ROB2009
61
Hello…. I’m currently using AirPlay II to stream Apple Music to Kef LS50 wireless II’s.
I’m looking to go wired to take advantage of higher quality music files… just wondering if anyone has any recommendations on DACS and / or connections to use into the Kefs?
Thanks…
Thanks…
Isn't the only wired output from the iPad going to be analogue??
No experience here by the way.
Is there a way to get a digital output from an iPad?
Fandango Andy
Thanks…
I would suggest you start with a quick look at the manual for your speakers to check what I am suggesting:
A quick google suggests you speakers have built in DAC's, and a USB B input, therefore a lightning (or USB C depending on the age of your ipdad) to USB B cable should do the job for less than £20.
Surely you need the KEF app to control your wireless speakers which then use their own DAC to stream various providers. That might not include Apple Music which seems incompatible with most streamers.
Reactions: DougK1
ROB2009
61
Yes I’m happy to use the Kef app, but I have Apple Music which isn’t supported in the app.
No USB-B on the speakers.
Not sure on the coax type, just says play content through coaxial (eg audio player)
Messiah
I'm not 100% sure but I think the only way you can achieve what you want is to use a DAC with a USB input (to connect the iPad to the DAC) and coaxial or optical output (to connect the DAC to the KEF's).
With regards to your original question about what DAC, it's been a while since I used an external DAC so others will be better placed to advise on that.
With that being said, I am not sure you would notice a big difference (if any) and Apple are reportedly working on utilising ALAC over Airplay.
I would agree. If that coax isn't digital then the inputs on the KEFs is sorely limited and the only way around it is an external dac with optical output, but will not this decide the maximum resolution you can actually transmit from the iPad?
ROB2009
61
It might, I don’t want to bypass the Kef amplification or DAC so will probably stay with AirPlay 2 for now.
I’ve had a look at the built in Connect apps, but the user experience is rubbish compared to Apple Music.
Appreciate everyone’s help…
Reactions: Messiah
I must admit that were those speakers to be mine, I’d look at Tidal, Qobuz, or Spotify.
Otherwise, I’d get a dedicated streamer and use digital out. A modestly priced Wiim would be a low risk experiment, plus a suitable length of coax digital cable. But, I don’t recall any streamers with native Apple Music functionality, which seems a massive blind spot on Apple’s part. This should be a few days work from an intern I’d have guessed, but what do I know?
Reactions: DougK1
Fandango Andy
Thanks… iPad has USB-C, the Kefs have Optical, coaxial and 3.5mm Auxiliary inputs.
Looks like I was misinformed about the USB input (I think that was the what hifi review!), however, I did find the manual online:
It looks like you do have a HDMI input. I have never seen a USB C to HDMI cable but it appears they exist:
Google took me to a few forums where people have suggested this method from iphone to amp which is effectively the same as you are doing.
Failing that you are looking at a usb dac such as Audoquest Dragonfly, iFi Go Link Max, iFi Zen DAC V2, FiiO KA2, or a Cyrus Soundkey if you can still find one.
