Compact centre speaker?
robthebubble
6
Does anyone know of a compact centre speaker available. Basically I want to mount it under the TV on the wall above the fire and ideally it will be set back in the wall. Many thanks Rob
It helps if youre centre speaker is of the same brand as your front speakers to maintain constant tonality, so i would recommend choosing one by the same manufacturer.
[quote user="Andrew Everard"]
What are the front speakers it has to match with?
[/quote]
Sorry for not getting back to people sooner! Anyway, I currently have a pair of Mission M74i's which I think are superb. I can't remember my current centre speaker but I know it is a KEF...I suspect its a Cresta but I can't be 100% sure unless I have a look later.
Basically my aim is to mount the TV on the wall but I want a small centre speaker...the KEP is 20 cm deep!
Any thoughts would be greatly appreciated.
Rob
