Cleaning Panasonic Plasma Screen
Personally i never use any type of "cleaner" i only ever use 2 good quality microfibre cloths - one very slighty damp first then a dry one after to buff
professorhat
992
22
18,895
stu31:Personally i never use any type of "cleaner" i only ever use 2 good quality microfibre cloths - one very slighty damp first then a dry one after to buff
Ditto - beware cleaners, espeically if it has a anti-glare coating as these will likely remove this.
A microfibre cloth is the best way as the other guys have aready mentioned but if the screen has dirt such as finger marks, then you will need a very very damp microfibre cloth to do the job.
