After enjoying the sound of my trusty Chromecast Audio through my Arcam Black Box DAC for quite some time, today I was shocked/appalled to notice that in the Google Home app, when I select the Chromecast Audio, there's an equaliser - and it seems to be changing the sound BEFORE it goes into the DAC.
So, I flatten the EQ and it loses bass and treble. Turn either up, and they go up. This is absolutely not want I want, nor would I expect. Surely any software EQ would be bypassed when connecting to an optical out and going into an external DAC? Surely?
I've looked into whether it's possible to switch it off or bypass it altogether, and whereas I suspect there may have been a way when the Chromecast Audio was a live product, I can't find anything about doing it through the Google Home app.
If not then I'm unsure what the EQ is doing, whether turning bass and treble all the way down is the way to go (I don't think so - it sounds very flat), keeping them midway as they were when I discovered (sounds OK), or what.
Perhaps my only option is to listen carefully to a CD, then flip between that and the Chromecast Audio, then play with the EQ until it sounds as close as possible to neutral. But this really annoys me. I use HiFi Cast with FLAC files so that can get bit-perfect reproduction, but clearly Google has inserted itself into my audio chain somehow.
Any ideas?
Thanks, Brendan
Any ideas?
Thanks, Brendan
