Hi i bought a pair of chord company odyssey 4 speaker cables of Ebay with no instructions does any one have any diagrams or advice on fitting this cable many thanks.
hifial:Hi i bought a pair of chord company odyssey 4 speaker cables of Ebay with no instructions does any one have any diagrams or advice on fitting this cable many thanks.
Do the cables have any connectors on the ends or are they bare wire?
Make sure you take off the jumper bars between binding posts on each speaker. Then it's a case of left red and blacks to amp red and blacks. The amp should have two sets of binding posts for left and right, but you might need to switch them on with a speaker selector.
igglebert:Make sure you take off the jumper bars between binding posts on each speaker. Then it's a case of left red and blacks to amp red and blacks. The amp should have two sets of binding posts for left and right, but you might need to switch them on with a speaker selector.
You look more handsome without the backpack Iggs. Like the hair.
