Chord chameleon .
I have a pair of chord chameleon xlr balanced cables connecting my yamaha as2000 amp and cd.
Any suggestions for any improvement in this department.?
Chord Chorus 2 is then next up in the range followed by the Anthem 2, but as the Chameleon is already a very good cable you would have to listen to use see if they made any improvments.
In considering you are now using Yamaha amp. Chord Chamelon should be sufficient. If you need better SQ you may consider upgrading either you CDP, amp. or speakers instead of interconnects.
