Cheapest Blu Ray Player Yet?
I tried it with some scenes from Attack of the Clones, and it looked and sounded fine. It can also play some PC format video and audio files, plus display jpegs, from a USB memory stick as well as disc, though I haven't tried this yet.
The menu system is clear and straight forward (with a lot less options than the Pioneer, but the basics are there). It also loads reasonably quickly.
One thing I forgot to mention is that is does make a low humming sound at times, only noticeable in quiet passages if you listen out for it. If you're used to an Xbox 360 it will seem quiet!
Hi ElectroMan,
Thanks for that, it sound's really good.
For £50 it certainly is!
This is the sort of thing that's needed to kick BD sales off - that and lower prices on the high street on the discs themselves!
