Change in Direction
At present l, mainly, listen to Spotify (Premium) through a PC, fitted with an M- Audio 2496 soundcard, Denon amp & a pair of Tannoy F1 Custom 'speakers.
l had intended, in the new year, to go down the active speaker route & was seriously contemplating the KRK RP5's; no need for separate amp & replace the Tannoys.
However, though the room is approx' 4 x 4 metres, we have an old unusual house with walls that have weird angles; hence the measurements are not square.
Long story short, it looks increasingly likely that the corner/alcove where the right speaker is will be taken up with a large flat screen telly. All usable options for placement of speakers the size of the Tannoys/KRK's will be gone, due to sightings of items of furniture, radiators etc
So, though l may come back to the option of KRK's in the future, l need to consider some active computer speakers, with or without a sub.
l have heard that the Harman/Kardon Soundsticks are good, though l don't particularly like the clear presentation.
Budget is in the region of £150 ish as, l say, l want to retain the option of larger active speakers for the future.
Advice more than welcome.
chesterfieldhouse:I have heard that the Harman/Kardon Soundsticks are good
They are, but if sound quality is more important than looks, I'd get Audioengine A2s, which are fabulous.
John, thanks.
Are the Audioengeine A2's that good? Certainly the reviews are very encouraging.
l like the idea of a small enclosure, would be ideal for my present need.
Anything more to add?
AVI ADM9.1's ? ...many threads on this forum and most people who own them are happy
Fahnsen:
dim_span:AVI ADM9.1's ?
For £150?!
soooory! ... too many beers ... never read the whole thread properly
