davedotco said:andyjm said:Sigh, it is diagrams like this that have created the problem.
1.The squiggly analogue waveform clearly has frequency components way above the frequency of the 'staircase' sample rate in the bottom diagram - you need to sample at twice the highest frequency component in the analogue signal for this to work.
2. The staircase waveform is shown before the low pass recombination / anti alias filter. The output of a D2A converter chip has to be filtered.
If the correct sample rate was used, and the 'staircase' output filtered, it would match the analogue signal exactly.
But, but, but, I can see the steps, it's obvious, it's going to sound all steppy.
Anyway, my ears are definitely analogue, if they were digital I would have 10 of them.
The is an argument to be made that ears are in fact digital. Sound pressure waves are transferred into fluid flow in the cochlear. This in turn stimulates hairs, that in turn cause neurons to fire that send nerve impulses to the brain. The neurons are discrete - either they fire or they dont. Sounds digital to me (if you will excuse the pun).
