I have recently moved house, so am starting to think about being able to play music again. I was tempted by the Arcam Solo, but it is a bit of a chunk financially in one go, so given I already have a decent amp, where to go?
The amp is a Cyrus 2, so I would have to spend quite a bit to better it, so I would like to hang on and make use of it for a while, so I am primarily looking at CD players, but I don't know what are the ones to really consider.
I am not averse to used or ex dem kit, so can flex the range available that way.
Realistically I am looking at £3-500, but have been wondering if it would really be worth the stretch to a Cyrus CD6s or a Kandy, especially as Kandys seem to be around the £500 mark ex dem. I am also wondering about slightly older stuff, like an Arcam Alpha 9.
I will also eventually be looking at adding a DAB tuner before too long, so the Cyrus option means I could go for an aesthetic match better there than with the Kandy, as the current Roksan Tuner is only FM.
Musically my tastes are wide and varied, but concentrate in the forties and fifties with western swing and country type stuff, through hendrix/cream springstein, some jazz and classical stuff up o the odd bit of modern stuff.
I don't have speakers either yet, as I am trying to find out if my wife prefers floorstanders or stand mount...
As you can see I am at early stages, with wide open options that are maybe a little too wide!
Thanks for any suggestions,
Paul.
Paul.
