Castles Rising
ESP2009
177
A couple of weeks back I took a bit of a risk and bid for a pair of Castle Richmond II speakers on Fleabay. They have finally been plugged in and I'm giving them a listen even now.
So, given that these cost me the handsome price of £36 (inc P&P) and the Spendor S3e pair cost £619.99 (inc P&P), what do I think?
Cripes, but they're plug-ugly! They look as though they were knocked up in someone's garden shed on a wet Sunday afternoon using an old sideboard. They have the appearance of true hi-fi: it doesn't matter how it looks as long as it sounds good, and we'll cobble together whichever parts sound best! Being a good few years old, they have the slightly battered but loved look about them that comes with being owned by a hi-fi fan who has enjoyed them, a family and at least one house move. They're solid and uncompromising. I've just put the foam panels back on - a definite improvement in the looks department. [🙂] So not very spouse friendly, then.
Sonically, I am taken aback. They are easily driven, pounding out music fit to wake the neighbours much more quickly than the Spendors. I wouldn't want to take them much past 40 (which is about midway) on the Primare's volume indicator. They have clarity in spades and dish up detail well. Toe-ing them in slightly quickly eliminated an imbalance in the soundstage which nows fills the wall opposite me nicely. Perhaps there is too much top end; certainly there's a touch of sibillance that the Spendors do not exhibit.
I started with Melody Gardot's second album, My One And Only Thrill, but have moved on to the Austrian rockmeisters, Serenity, who are pounding out Words Untold and Dreams Unlived quite merrily and convincingly. OK, not the last word in bass power, but holding it together well enough to provide a driving beat that stands out rather than being a dull background thudding. Next up is The Lens and the opening track of A Word In Your Eye - that should test them! Hmmm, not bad. The heavy bass-line is not too flabby and out of control. However, I believe that the top end is just that bit too dominating whilst lacking some of the sense of space I have heard the Spendors give. There is no doubting the clarity and zing even if there is that slight extra sibillance to mar the overall performance. For their age, they seem to have a lot of youthful enthusiasm about them. Maybe refinement is an alien concept for these chaps? I have to say they are loving Jean Michel Jarre's 30th Anniversary edition of Oxygene. It's crisper than I expected and taller than I had previously noted. And now onto Rimsky-Korsakov's Scheherazade and we certainly get a sense of a large orchestra playing, but unless it is the fault of the recording the sound is that bit too brash and strident at volume. Finally, a quick burst of Blackmore's Night and it confirms for me that if you want clarity and detail for vocals, guitar strings, tambourines and such, they are great, but I imagine that if you play them loud they will soon become fatiguing because of the bright edge.
So, for £36, I reckon the Castle Richmond IIs are quite bargainous. I will certainly get them hooked up in the front room when we get that far. Which, in a way makes me feel quite certifiable if I am considering a sum of up to £1500 on a new pair of speakers for the living room! Something costing that much is going to have to deliver something quite wondrous!!
Back with the Spendors now and I can hear a world of difference, although at least part is down to personal preference. The Spendors (apart from looking more sophisticated) sound more of a complete package - the sound is more integrated and rich. Yes, there is still detail and clarity, but there is added balance. The bass is more powerful but not overwhelmingly so. In a way, the Castles give an illusion of greater space and air on some tracks because the top end is so bright. The Spendors aren't so obvious and yet paint a better soundstage and more balanced sound.
Begs the question: why do I want to change them? Well, maybe I won't!
You can get the Castles out when you fancy a boom-tizz blast! For that price they're competitively priced firewood in this day and age! Spendors are quite good at being difficult to replace. Many find them uninspiring but they charm you in time
Get yourself a demo of the Spendor A5 and see where that leaves your appetite.
ESP2009:
Interesting: By the sound of it, the Castles could do with a more recessed sounding amp like Arcam or Nad...
I'm also finding these old Wharfedales, albeit don't exhibit the all-round abilities of my old RS6s, have a sound that is immensely pleasant - good enough to define different amps with aplomb.
Are these Castle speakers Biwireable? If yes you can try putting a resistor between + terminal of the tweeter unit and the speaker wire that goes to that same terminal, that should tame the highs a bit. Let's say a 4 to 5 ohm resitor might do the trick. If they are not biwireable then you would have to open the speaker to do that. I also have seen the crossover frequency is pretty low at 2200 Hz on these speakers. if you can get it somewhere at 2800 hz with a capacitor of a lower rating then the one that the speaker now has, that would also make a big difference on the sound. It should make the speaker sound better, less bright and you will have fun doing it if your up for it.
RCduck7:Are these Castle speakers Biwireable? If yes you can try putting a resistor between + terminal of the tweeter unit and the speaker wire that goes to that same terminal, that should tame the highs a bit. Let's say a 4 to 5 ohm resitor might do the trick. If they are not biwireable then you would have to open the speaker to do that. I also have seen the crossover frequency is pretty low at 2200 Hz on these speakers. if you can get it somewhere at 2800 hz with a capacitor of a lower rating then the one that the speaker now has, that would also make a big difference on the sound. It should make the speaker sound better, less bright and you will have fun doing it if your up for it.
No, there is no facility to bi-wire. They would have to go under the knife, as it were. Not really my thing. Still, they can go in the other room and at the volumes the Sound Police plays, she won't care how fizzy they are!
igglebert:You can get the Castles out when you fancy a boom-tizz blast! For that price they're competitively priced firewood in this day and age! Spendors are quite good at being difficult to replace. Many find them uninspiring but they charm you in time
I might have known you would have been along sooner or later, Iggles. Always trying to lead me into temptation, you evil chap!
