- Jan 29, 2013
- 1
- 0
- 0
Hi. I am looking to upgrade the Elys 2 cartridge on my RP3. Unfortunately a demo is not possible so I will be buying blind (or is that deaf) over the internet.
While I generally the enjoy the musical sound of this combo, I do find it can sound slightly dull & 'closed in' at times. I would like a cart that would give me a brighter, more dynamic & open sound. I guess the logical choice would be the Exact, but would this give me the desired results? Does anybody have any experience of the RP3 + Exact, and in particular, upgrading from Elys to Exact?
Now the other consideration is that I will be fitting the cartridge myself so it would have to be reasonably easy to fit. With this in mind, my other option is the Ortofon 2m Bronze, with its captive nuts plus the fact it looks like it is designed to fit the Rega headshell. However, I understand that this option would also require the fitting of VTA spacers for the arm mounting. Would this have a detrimental effect on sound quality in compromising the arm mounting in this way?
Any input would be greatly appreciated.
Many thanks.
Many thanks.
