can i connect a humax hd to...
cheers daveh, theres one yellow and one green component video output, my component cables are red and blue, which goes to which? ta...
top man daveh, thanks..
my component cables are dual point, one red one white, i presume i need a triple point one ?
ah, no bother daveh, ill just use scart for a couple of days so
ah, yep thats a plan..
i guess its not possible to connect to my sony blu-ray player with component? id love to see what avatar looks like on this little tv
maxflinn:
Yes you can. Remember, you will also need audio cables as component is video only. Also, don't get mixed up with composite cables - component is red, green and blue. You can get some brilliant cables on eBay for under £20 as hdmi has taken over.
On a similar theme, does anyone Know whether you can scart a Humax HD Freesat receiver to an old CRT TV and be able to use the SD iPlayer function (or can this only be achieved through an HDMI connection)? I have emailed Humax with this question, but did not get any response.
I would be grateful for any help
Gerrardasnails:maxflinn:
i have three sets of cables, dual point, red and white, will they suffice gerrard? ta..
maxflinn:Gerrardasnails:maxflinn:
Strictly speaking they're audio I/Cs, but they'll carry component video no problem as will composite cables...Don't waste your money on 'component' cables max, especially as it's a short term solution.
will the hdcp prevent blu-rays from playing over composite output?
a friend who lent me the tv reckons it wont work...
