Hi There,
I've been pondering over Sonos and Marantz CR603 based systems for a while. But having already got good digital sources [Mac Mini, Sky HD, Spotify Premium, iTunes, Internet Radio etc] I decided my limited budget would be best used on a solid amp and speaker setup - aided by a Beresford or CA DAC. I was also fairly limited by speaker size due to the having to position them on an existing oak AV cabinet.
So having not been able to locate any stock of my first choice speaker [Q Acoustic 2020] I settled on an all Cambridge Audio setup of a Azure 350A amp, DACmagic, and S30 Bookshelf Speakers. So having agreed a decent discounted price in the Romford RS store I returned home to cable up. As I had all the interconnects I needed to get this up and running from previous AV setup I didn't buy any new cables - i'll come back to that...
Set up complete I can say the build quality of the CA kit appears to be very good and solid. The S30s are a revelation [see my comments on WHF review]. The DACmagic is exactly that... taking the DAC out of the loop leaves all source material sounding pretty dull and average sounding. Back through the DAC and the sound is big, open detailed and very precise - all said it just sounds quite amazing to my ears. Which brings me back to my old cables... so the optical cable from Mac to DAC is cheap CA from a few years back, the interconnects are no brand chunky affairs [probably from Comet or somewhere - I just had them spare] and the speaker cable was some Hitachi [pretty heavy stuff - not bell wire but no pedigree]. And despite all this the setup sounds superb!
The dilemma was how quickly [if at all] to spend the £150+ to upgrade interconnects and speaker cables to Chord or the like... I'll never forgive myself if I can release even more performance from the setup so the order is placed. I can't wait to see the difference this makes!
In summary if you are looking for a great looking, feeling set-up for an average sized room for digital sources then don't overlook Cambridge Audio kit - especially used together where unsurprisingly they appear to be perfectly matched. Happy to answer any questions about my setup.
Thank you to Richer Sounds - especially Romford for having stock.
