Cambridge’s top-of-the-line DAC is a superb performer with plenty of features.
Cambridge Audio DacMagic 200M : Read more
Another question the review leaves unanswered.Are the outputs variable, ie is it a preamp?
I'm not so sure about assuming it is. I've read a little about this because I was in the market for a preamp a little while ago. I can't find it being confirmed a preamp anywhere, even though the volume dial is mentioned. You'd imagine CA would even market it mentioning all it's functionalityAnother question the review leaves unanswered.
We can pretty much assume it can be a preamp, but the review could (should) have confirmed it.
The CA specs do say that it has a 4.4V RMS output fixed or variable, user selected. So yes, as you'd expect, it can be used as a preamp.I'm not so sure about assuming it is. I've read a little about this because I was in the market for a preamp a little while ago. I can't find it being confirmed a preamp anywhere, even though the volume dial is mentioned. You'd imagine CA would even market it mentioning all it's functionality
This is only a DAC though Patrick.Maybe Cambridge can consider a ‘+ version’ with Tidal and Spotify connect. Personally I think they can take a very large part of the streamer market with that (best output and no 3rd party apps)
No doubt they'd point you to their CXN or 851N streamers - which must? be able to stream Tidal and Spotify Connect?? (I wouldn't know, because I'm not interested myself).
MQA seemed like a good idea when I first read about the principle.They’re bound to update these with MQA compatibility as with the 200M. In fact it’s very unusual to include full MQA decoding in a standalone non-streaming DAC. Which leads me to believe the 200M is more suited to PC/laptop duty than anything else.
Got to disagree with you on that ... it's not so uncommon among higher-end product lines, just like DAC-less streamers. And the balanced circuitry here does not to me signal that this is primarily suited for PC/laptop duty.They’re bound to update these with MQA compatibility as with the 200M. In fact it’s very unusual to include full MQA decoding in a standalone non-streaming DAC. Which leads me to believe the 200M is more suited to PC/laptop duty than anything else.
Doubt it's something I'll ever want / need / have though - especially if it means paying monthly subs to any streaming outfit.
Yep ... and they also tend to have balanced circuits and XLR ouputs ... all of which, to me, makes this relatively reasonably priced, balanced, full MQA-unfolding, streamer-less DAC fairly compelling.Those DAC-less streamers will be pretty expensive.
I'd never have used it if it wasn't 'Spotify Free' is what I use. (And so infrequently that they've repeatedly e-mailed to tell me why I should be using it more).Spotify is not free, Tidal don‘t charge extra for MQA over and above streaming at CD+. quality.
The review states why the headphone output has the potential to sound better.....but doesn't say whether it actually did.
The whole point of reviews is to get at this sort of thing! They're supposed to test the product and tell readers about it. And they're supposed to evaluate manufacturers' claims, not just take them as gospel.Wouldn't it be just as easy to ask the manufacturer? In general, reviews are not the be-all and end-all, there will always be questions people will have about any product.
So What Hi-fi? should leave out audio performance in a review of an audio device? Seriously?Yes but you can't cover every aspect of every product, we mistakenly tried to do that on our own retail site at one point and ended up with 8-page reviews. This is clearly just a short review to give potential buyers a reasonable idea of what they're buying, not a "bible" on the product. It's not unreasoble to assume that manufacturers are telling the truth about their product but as I said, it would have been just as simple for anybody to ask the manufacturer if they were that interested.
The review of an audio product left out a detail about its performance (the performance of the headphone jack). That's fair game for criticism. If anyone is making this more complicated than it needs to be, it's you.You're turning a simple point into an entire, relatively pointless, debate. This is a relatively short but decent review that gives anyone reading it the opportunity to reach the conclusion that it performs very well. As I said, you can't have a concise review that covers every potential eventuality, I'm not sure why you have a problem understanding that. If you're not happy with the review there are plenty more on this particular item. What our retail site is, is completely irrelevant, the point I made applied to just about every product.
The original question asked, which wasn't even your question, was about whether or not the headphone output has the potential to sound better, not about overall audio performance. All I did was make a simple point that it would be just as simple to check with the actual manufacturer, you're blowing it out of all proportion. I'm out.
John Darko stated that the headphone output of the iFi Zen DAC v1 was far superior……perhaps that’s why What HiFi left it out? 🤔The review of an audio product left out a detail about its performance (the performance of the headphone jack). That's fair game for criticism. If anyone is making this more complicated than it needs to be, it's you.
