cable binding?
I have just moved to my new house and slowly setting up my system just running 2 x fronts at the moment, the rears im planning to wire in behide my skirting boards as there off at the mo waiting for new to be put on.
the cable is QED micro now the thing is the two pieces of cable i have are far too short after mesuring im gonna need about 30m lenght for the two cables i know its not expensive but its still about 80-90 quid.
At the moment the cables i have are around 10m and 12m which aint enough my question is should i buy the extra lenghts and bind them and use insulation tape which will save me a few quid but will this effect quality or not work or simply taking a risk that they could break up on or un-bind over time.
If problems occur i would be unable to access the cables as they would be behide the skirting boards.
any advice or tips on binding?
Messiah
528
362
19,270
If I was gonna tuck it behind the skirting then I would want it done right and not have to worry about it.
I would buy a new length rather than bind 2 together.
Olli1324
48
If soldered and insulated with heatshrink and/or insulation tape, there shouldn't be a problem. The joint will be far better than where they are attached either bare wire/banana plugged to the amp and speakers.
If having continuous runs would give you better piece of mind, then you are probably best off selling the short runs and just plumping for some new stuff.
As a tip now that you are setting up your hifi again, it might be worth re-stripping the cable ends so that you get a good, fresh, non-oxidised connection.
fayeanddavid
191
+1,
just for peace of mind if nothing else
