Xanderzdad said:
Vladimir said:
Took me couple of hours to reinstall every application I need and tweak Win 10 to be fast and efficient like Win 7 before it (although I can't make it boot faster). It's not a problem really. Thanks.
Out of interest what tweaks did you make to W10? (Mines running off an SSD, with all the Data on an HDD.)
I would also recommend MusicBee as it seems to have the best features of iTunes, Foobar & Groove but without the bloat. Looks really good too.
I did different tweaks on the laptop and the desktop considering the laptop uses 2xHDD and the desktop SSD+HDD.
1) Typically you want no useless background processes running at startup and during your use of the machine. I turn them off through Task Manager > Startup, through Services, and System Configuration. What to dissable depends on your hardware and choice of applications installed.
2) In System Properties I increase the Virtual Memory to 8192MB per partition and I set Visual Effects to Adjust For Best Performance (keeping only Show Thumbnails and Smooth Edges On Fonts ticked). I also keep no photo background on the desktop, just solid color black.
3) Disk Cleanup using the option Clean Up System Files, including deletion of the old Windows folder (C:/Windows.old). Then defragment all HDDs (never defragment SSDs, have the weekly auto defrag. disabled for your SSD). Defragment the OS HDD 2 times.
4) On the laptop I use a 4GB flash memory card in the card reader (formated as exFAT) with ReadyBoost, to improve the paging file process. I don't bother doing this on the desktop machine because it has an SSD. At first run you don't feel anything has improved, but it takes time for Windows to learn my habbits and to anticipate them in the future. Give it few days, open and close your most frequently used apps ocassionally to help it learn faster.
I want as much RAM and CPU free as possible before I open a resource demanding application to work with (example Adobe Illustrator, Photoshop, CorelDraw). You would do more aggressive tweaks if you're a gamer. This is all pedestrian stuff.
