My advice is to forget about individual components.
Visit few specialist dealers and listen to their complete systems that fall in your budget. Take your music with you and just sit and listen.
There will be different approaches to reproduced music and you will enjoy some systems more than others. It took good dealers many years to find what really works good together. Just buy complete system from one dealer and forget about, what if... I change this or that. Most likely, if you change one thing, everything will fall apart.
Your budget is big enough and you should find something very special and pleasing for you.
For start, try to find a dealer who stock Rega/Naim + Kudos and some other speakers (perhaps Spendor, KEF, PMC), and another that has Croft + Harbeth. Then find a dealer with e.g. Dynaudio speakers and listen to his system. After this 3 visits you will know much more.
