Budget speaker package
Given that the Wharfedale Diamond 10 HCP is a 4 star product, I was wondering if one could use 2 pairs of Diamond 10.1's plus a suitable Wharfedale centre speaker to create a good speaker package (subwoofer optional).
Yes thats what you get in the av package 2 pairs plus 10cc centre and 10mx sub. Cheapest for the 10.1 pair of speakers is £199, centre £100. So thats £500 and then you need the sub why not buy the complete package for £650, and if you need an amp im sure you will find even better deals.Also i would consider the cheaper Q Acoustics 1010i package at £350, or if you can get to Richer Sounds theu where selling them in pairs for £39.99. Here's a link for the Wharfedale.
http://www.stoneaudio.co.uk/
Or you can put on a set of 9.1s+ centre+ sub for the same money as the HDP 10.0 package.
