Budget HiFi System
tele1962
49
I can probably guess this question will have been asked many times, but it is a minefield out there. So here goes.
For a budget of around £450 and will be used mainly for Vinyl, what would you good people recommend.
(PS, returning to HiFi after nearly thirty years and making a big mistake of selling off my Vinyl Collection, mainly The Beatles, Pink Floyd etc)
Thanks in advance.
Thanks in advance.
I'd might go for a set of Roth audio va4 and a project primary. That leaves about 70 for a nice set speaker stands
The first question is why vinyl? i only ask because it's way more expensive than any other source if you want to do it properly. And to be brutally honest, unless you're going second hand and you know what you're doing, you'll struggle at that budget.
On the other hand, you'd get a cracking cd based system for that kind of money if you shop cleverly. Others will be able to give better advice than me, so I'll just stick to the standard "listen to as many components as you can"!
Good luck! Sorry I wasn't more help....
It's probably a lot to do with The Beatles albums i loved so much getting a new lease of life, also the beutiful warm sound of vinyl for me is just superb.
I was thinking this set up:
Pro-ject Essential 2 turntable
Mission LX2 loudspeaker
Cambridge Topaz AM5[/b]
Hi again. Project basic turntables are pretty good value for money - I had a debut phono before my Rega.
That tunrtable doesn't have a built in phono stage, and neither does the amp as far as I can tell, so you'll need to budget for one of those, or perhaps look at a different amp that has one included.
The other important thing at that price will be to get the cartridge right. A post in the turntable section will be a good place to start - they are a very knowledgeable bunch on there. My favoured first upgrade cart is the Ortofon 2M Red. At around £80-90 I reckon it's a belter, but others will certainly disagree!!!
If you can manage to add a decent aftermarket cartiridge it'll give you a huge upgrade in sound performance.
As far as i know the deck comes with an Ortofon cartridge.
Not sure what a phono stage is though.
Sony str db930 (good phono stage, DAC'S etc.), new rega RP2, Mordaunt Short ms20i pearls plus 30 quid on cables.
Sorted.
I would advocate second hand for this budget, and there's plenty of options out there.
A nicely cared for Dual CS505 or CS503-2 will do a great job as a turntable (and better than a basic Pro-ject). Pioneer PL12D and Sansui SR222 are also plentiful at very affordable prices and, with an AT95E cartridge on, will do a great job.
For the amplifier, a nice Sansui AU217 if you are happy to go vintage, or something along the lines of a Rotel RA01/RA04 will make a great choice.
For speakers, JPW Sonata, Mordaunt-Short MS20i, Celestion 3... There's loads of good options out there.
That should give you a great set-up and leave some budget for hunting down some nice second hand vinyl to play on it. It's absolutely what I'd do.
Thanks for the advice. Apart from the likes of EBAY are there any sites for purchasing used hifi equipment. I remember Richer Sounds did this years ago.
Looks like i am defo going down the used route at least for part of my system. Members on other forums seem all to agree this is the way forward.
Entry level Project or Rega turntable with same Marantz PM5004/5 amp (with built in phono stage) along with Q Acoustics 2010 or 2020 speakers will sound very nice indeed all of which are available online new or second hand via ebay. Pick up some second hand stands - Atacama are good - and you are on your way and within budget or there or thereabouts. Other good kit available on a budget which sounds nice from Nad, Yamaha, Pioneer, Monitor Audio and Dali.
Good luck and let us know how you get on
That is a very sensible decision. I prefer German ebay to UK ebay. I also like taking touring holidays on continental Europe, which helps when it comes to collecting kit.
If you can do some basic DIY repairs, such as replacing foam surrounds on speaker bass drivers, you'll be able to get so much more for your money.
For TT's I'd go for a direct drive such as a Micro Seiki DD 1 or Sony PS-X6 instead of a boring belt drive.
Check out the Lampizator pages for some interesting reading. Some of the CD players that he rates highly can be bought for £20. You might as well add one to your system, especiallly with used CD's being so cheap now.
For amps, I'd just go for the cheapest integrated or pre-power I could find that had an MC phono stage - which would probably be a Japanese integrated solid state from the likes of Sony, Pioneer, Sansui, Kenwood.
Speakers. Maybe something small and under £100. Like 1980's to 1990's Heybrook, Missions, Royds.
Thanks mate, i might have the chance of some equipment soon Marantz PM6003 & Kef Q100's for starters (this is just a maybe).
Can you link me to the Lampizator artical please.
http://lampizator.eu/Fikus/WELCOME_TO_LAMPIZATOR.html then look through the archived blog
http://www.lampizator.eu/lampizator/goodplayers.html
The players at number 3 on his list with the TDA1549 DAC can be had for about £20. That's a good price performance compromise.
http://www.lampizator.eu/lampizator/REFERENCES/Philips%20CD751/Philips_tda1549.html
Deposit payed and system will be.................drum roll
Project P2 with Ortofon Cartridge
Marantz CD6003
Marantz PM6003 Amp
KEF Q100's Speakers.
All purchased from Hifisound Ltd in Stockton On Tees, the best Hifi shop i think i have ever been in all my life, with staff that went above and beyond to help out.
Demoed these all today with an expert friend of mine and were blown away by what we were hearing, threw everything at it and it just got better and better. The soundtrak from The Last Samurai, Black Hawk Down, Abbey Road The Beatles, some Bjork, Mike Oldfield and more that i can't remember as it was just one fantastic thing after another.
