That's an important aspect on a very expensive product.These are NOT analogue compatible. The 3.5mm jack is attached to a usb.c which internally converts all sound to digital max 24/48 bit. No vinyl or hirez 😂. Mine returned.
They are wireless headphones and that should tell you something.These are NOT analogue compatible. The 3.5mm jack is attached to a usb.c which internally converts all sound to digital max 24/48 bit. No vinyl or hirez 😂. Mine returned.
