- Aug 10, 2019
- 2,556
- 5
- 0
Hi I've got a new Sony STRD2400es (brought in Nov but only now tryiny to get working as finally had room built) connected to a Boston Soundware XS speaker system. However, I can't get the sub to work. I'm fairly sure the cable is OK and the sub is OK but can't get the amp to recognise that its connected.
Any easy tests I can try to 1. Check the sub? 2. Check the Amp? rather than carting it all off to the local shop.
Any tips on configuration, in case I'm missing something obvious. I expected it to be plug and play!!
