Boston Soundwave XS, Canton Movie 75, Mission M-Cubed or Cambridge Audio S215?
TheOne
17
Hi all,
looking to purchase one of the above sets. Originally had a budget of £250 (Bostons, Cantons) but because of the size I need, will to go up to £500 (Cambridge, Missions).
Reason for needing small satellites is a combination of the wife but also need the centre speaker to be maximum 100mm so as to not obscure the TV screen. Is there significant enough difference between my 2 price points?
Looking to pick them up tomorrow lunchtime so any advice is much appreciated!
Thanks!
TheOne
17
After much deliberation, went with the Cantons in the end. Left enough of my budget to get the Denon AVRX520BT.
Entry level amp but has 4 HDCP 2.2 inputs! Everything else around that price range only had 1. No reviews anywhere on line but took a punt and will set it all up this evening!
Both for less than the Cambridge and M-Cubed!
TheOne
17
I've got questions around the Denon AVR which I purchased but will moved this to a new thread on the receiver sub forum.
Cheers!
